Importing DWG/DXF to 3 different views or planes ?
Hello.
After importing a DWG file...,
How can I get that NX automatically recognize what region of the draftig goes to every view or plane?
What I've seen till now is, importing the whole drafting to the model and then manually select each region (drawing a rectagle around the curves) and rotate it 90º to set it onto the desired plane.
If I import it to the drafting directly, I think NX doesn't identify the different views, it places it as a single large drafting onto a unique view.
I attach an example DWG file.
