Write NX feature name as Object Name in Parasolid Export
Dear NX experts
I am trying to export a NX ".prt" file as Parasolid for CFD/FEA analysis. The objects do not have any features / parameters associated except for a feature title name like this Body(4) "FluidFlowpath".
I am trying to use a Journal file to get the feature name associated with a body such as "FluidFlowpath" and assign it as body name in Parasolid file.
few code lines from my NX file
-----CODE SNIPPET TO PRINT FEATURE NAME
' loop through all bodies in display session
For each obj As Body in bdyCol
bdyFeat = featCol.GetAssociatedFeature( obj )
strBodyName = bdyFeat.GetFeatureName.ToString
lw.WriteLine("Object Tag: " & obj.Tag)
lw.WriteLine("Object Type: " & obj.GetType.ToString)
lw.WriteLine("Object Name: " & strBodyName )
Next
The output is shown below. I could not get the feature name "Fluidflowpath" with the GetFeatureName command and get only the Body #. What is the command to extract the name "Fluidflowpath" I have associated with the Body.
-----OUTPUT
Object Tag: 27166
Object Type: NXOpen.Body
Object Name: Body(1)
Object Tag: 26889
Object Name: Body(2)
Object Tag: 26922
Object Name: Body(4)
Information about the body
Feature status for: FluidFlowpath(4)
Feature is alive
Owning part H:\FinalAnalysisModel.prt
Owning layer 1
Modified Version 201 25 Mar 2014 17:28 (by user )
Created Version 144 05 Mar 2014 15:49 (by user )
Feature Parameters for: FluidFlowpath(4)
Feature Type - Body(4)
Feature Associativity for: FluidFlowpath(4)
Ravi
Next
-----OUTPUT
Object Tag: 27166
Object Tag: 26889
Object Tag: 26922
Feature is alive
Owning layer 1
Ravi
RE: Write NX feature name as Object Name in Parasolid Export
With strBodyName = bdyFeat.Name you get the user defined name.
Hope this helps.
Frank Swinkels
Ravi
