What is the alternate for Geometric Properties command in NX8.5
Hi All,
Looks like the Geometric Property tool under Analysis is now gone.. Only way to get to it is through Command Finder..
What is the alternate to it? its an awesome tool..
RE: What is the alternate for Geometric Properties command in NX8.5
Analysis -> Local Radius...
BTW, if you had moved your cursor over the 'Geometric Properties...' item once it was added back on the pull-down menu the 'bubble help' that would come-up would have made that suggestion.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
The old Geo Prop tool used work across Entire Assembly.. But the new one works on work part only.. I tried to toggle the selection intent tool bar to change the focus to Entire Assembly, its not available..
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Done that.. :)
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
