SA-563 DH Nut Impact test?
When you use SA-354 BD studs, the ASME Section II says they shall be used with SA-563 DH nuts.
ASME VIII DIV.1 UCS-66 gives an impact exemption temperature of 20°F (-7°C) for the SA-354 BD studs but I cannot find the exemption temperature for the nuts.
Does anyone know where to find this?
The vessel design has an MDMT of 6°F so I know the studs will have to be impact tested, but I am trying to figure out what is required for the nuts.
Cheers,
JDMech
Cheers,
JDMech
RE: SA-563 DH Nut Impact test?
