Space Joists
Space Joists
I am interested in this product known as a space joist....wood flanges, metal webs for some development work (one project is commericial, the other multi family duplex)
Like these: www.spacejoist.com
Has anyone used these? The first question my clients are asking is how much more it costs than conventional wood I joists.
Field modifications seem impractical. The manufacturer says they come with trimmable ends.
Any experience with this type of product would be appreciated.
RE: Space Joists
Looks to be a well thought out product integrating the best of both products. I would be interested in seeing a cost comparison with the other joist types for the same spans, and if these are available on the West coast.
Mike McCann
MMC Engineering
RE: Space Joists
I like that concept very much, but their website is so sleazy, that now I have suspicions about the product and the company backing it.
The bottom line is cost, and chances are, they are the most expensive option short of going to all-steel.
The definition of a structural engineer: overdesign by a factor of 1.999, instead of the usual 2.
RE: Space Joists
RE: Space Joists
RE: Space Joists
They only seem to work well in open floor plans.
RE: Space Joists
RE: Space Joists
Open web has obvious pass through benefits compared to solid web,
The iJoist style end makes it field trimmable which captures a significant advantage of an iJoist and eliminates the too-particular fitting issues of some of the open web joists.
I personally like the web to chord connection as I prefer the many nails of the press-plate to the single bolt or pin of so,eyeing like the trus joist products, although the pin is elegant, I kinda like not removing wood material for bolt holes especially on tension chords.
I know nothing about costs, manufactured quality, engineering values etcetera, code acceptance.
RE: Space Joists
They need to list the ICC reports, and most of all, give design info - load tables, the usual stuff.
Otherwise I never take any product seriously, and this website is horribly designed.
