Creating cone flat pattern in sheet metal
Don't use sheet metal much.
Is it possible to create a rolled cone in solid edge ST6 and then use sheet metal to make a flat pattern?
RE: Creating cone flat pattern in sheet metal
I have also attached a picture showing how big you can go. I have made several very large cyclone systems with a single lofted flange and then in part mode, using divide part, sectioned the single large cone into manufacture-able sizes that will fit on our 5'-0" x 10'-0" laser table. The parts in different colors are all sized to fit our table as IPC parts driven from the larger master lofted flange PSM file.
HTH,
Ryan
Ryan Gudorf
CAD/CAM Supervisor
Budde Sheet Metal Works, Inc.
Windows 7 Professional x64 SP1
Solid Edge V20
NX8.5.1.3
TC8.3 in Testing
6 GB RAM, nVIDIA Quadro FX4800
Ryan
Ryan Gudorf
CAD/CAM Supervisor
Solid Edge V20
NX8.5.1.3
TC8.3 in Testing
