Can AISI 1215 steel beam rust
Want to know is AISI 1215 steel easy to be rust? any rust resistance comparison table....
RE: Can AISI 1215 steel beam rust
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
AISI 1215 is a free machining carbon steel, and as others noted its corrosion resistance is similar to other carbon steels.
Are you sure you meant AISI 1215? Are you asking about bare 1215 steel, or are you asking about 1215 steel with some form of surface coating?
I believe S45C is equivalent to AISI 1045 carbon steel. Higher carbon content than 1215, but similar corrosion resistance.
