I have some very basic GD&T questions....working to ISO/BS8888
Hi guys,
I consider myself to have a fairly good handle on GD&T (except for these little queries) and have been trying to implement it over the past few months, however got a couple of niggling questions hopefully someone can answer.
1.) Say you have a rectangular block with a size dim across 2 of the flats of 10mm +/- 0.1mm. Is there/what is the indirect parallel tolerance of that part? I understand the ASME standard has rule #1 which I understand but I don't believe there is such a rule for ISO - Except for the "envelope" requirement which is a different kettle of fish that I'm still getting my head around using also.
2.) From everything I've read and been advised, anything that is a FOS can have a size/tol dimension....Now what do I do with size dimensions for things like a blind hole where the depth dimension isn't a FOS, how should I treat those particular "features" (bottom of the hole surface, whether they be crucial of non crucial) seems a bit overkill to add a basic dimension and use position or surface tolerance?
Hopefully the questions are fairly self explanatory, when I'm back in work tomorrow I may upload some diagrams to help illustrate my questions if required.
Kind Regards
Kind Regards
RE: I have some very basic GD&T questions....working to ISO/BS8888
John-Paul Belanger
Geometric Learning Systems
Have you any thoughts on my 2nd question?
As for Q #2, there might be some legitimate disagreement about this, but I am in the camp that plus/minus tolerancing is really only for size dimensions (as well as chamfers and radii). But not for location. And as you say, the bottom of a blind hole is not a feature of size, so I would use profile of a surface (or position in BS/ISO), along with the basic dimension ("TED" in ISO). I don't think it's overkill; it's clearly stating what is needed, since a caliper-type size check can't apply there.
John-Paul Belanger
In your opinion, what is the correct way to specify depth of the hole, one to the left or one to the right?
On the picture to the left the diameter of the hole can, but does not have to be basic.
I am sure we both can immediately find at least two figures in the standard where such a practice is shown.
On the other hand, if the profile tolerance was indeed intended for only the pointed bottom of the hole, then the diameter wouldn't be basic.
That aside, I clearly said there can be legitimate disagreement about this. The depth symbol exists in the standard, so there's a reason for it. But I would ask how we measure the depth as expressed on the right picture -- is it take from a plane hanging over the top of the hole?
John-Paul Belanger
