Welding Symbols
Welding Symbols
Welding Symbols
Welding symbols are not showing correctly. Using AWS, there is no symbol for melt-thru and the flange corner is upside down. Melt-thru is suppose to be a solid filled half moon, they only show up unfilled. Any way to correct this? using NX7.5
RE: Welding Symbols
You may not have it set correctly in your customer defaults:
File -> utility -> customer defaults
and then what I did is I enetered weld symbol in the binoculars, and then look for something in the Standard catagorey
