BH-36K Material
BH-36K Material
BH-36K Material
I have a LPG sphere and the construction material says the material is BH-36K. Does anyone know what this is or where I can find information about this material? I have not seen this before.
RE: BH-36K Material
BH-36K is short hand where I am for Bake Hardenable steel to yield strength of 36KSI. I don't know which steel you are starting with.
RE: BH-36K Material
Standard Steel Grades
In addition to our specialist steel grades we also supplied standard steel grades in various thicknesses. For more information please see below or get in touch on 0121 556 9919
Grade Thickness Notes
BS EN 10025 – S275JR 6mm – 200mm 6mm - 15mm plate is fully certified. – mechanical and chemical analysis. 160mm to 200
BS EN 10025 – S355J2+N 6mm – 600mm - up to 1000mm on request Fully certified high yield steel with impact tests to -20 degrees celsius
BS 970 EN8(D) C45 6mm – 400mm Certificates to analysis. High Carbon steel for toolmaking and similar
BS970 C60/EN9 Selective range up to 100mm To analysis high carbon steel for cams and wearing services
A516/GR70 + other grades 8mm – 200mm Fully certified boiler quality steel
Keiton Engineering Co. Ltd | Steel Profiling | Lumsden Grinding | Steel Suppliers, Stock specialist steels
