machining environement preferences
When I open a new machining setup, I can't chose the option browse a template file? I really don't know why. Plus, when I go to my machining environement preferences, under the configuration box I can't open the configuration file or template. Is it some sort of settings I didn't found, is it normal?
Thanks for your help.
RE: machining environement preferences
I cannot open the attachment, so perhaps you can describe this.
Are you opening a setup, OR creating a new setup?
Are you using File New --> Manufacturing?
What is your cam configuration - cam_general?
Mark Rief
Product Manager
Siemens PLM
