Vertex
Vertex
good afternoon
i just want to know if a can get the coordinates of a vertex (no points) and if the GetCoordinates will also work
Thank you for your answer
RE: Vertex
hope you can help me with this
Language="VBSCRIPT"
Sub CATMain()
Dim mycoord(2)
Set partDocument1 = CATIA.ActiveDocument
Set selection1 = partDocument1.Selection
selection1.Search "Name=Surface.48,all"
Set selection = partDocument1.Selection1
selection.Search "Topology.Vertex,sel"
Y = selection.Count
For i = 1 To Y
Set reference1 = Selection.Item(i).Value
reference1.GetCoordinates (mycoord)
xc = mycoord(0)
yc = mycoord(1)
zc = mycoord(2)
MsgBox xc
MsgBox yc
MsgBox zc
Next
End Sub
RE: Vertex
Why not extracting vertex in point in a separate Geometrical Set? Should work something like extract vertex, isolate, then change from Explicit point type to Coordinate point type... do it first manually to see if is what you want.
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
