PRESSURE VESSEL HYDRO TEST
What would be the hydro-test pressure for a vessel with MAWP 311 psi, rolled from SA516-70N, with .875" nominal thickness? And how is this calculated. Max temp. is 230F and Min is -20F
RE: PRESSURE VESSEL HYDRO TEST
311 PSI x 1.3 x 1.064 = 430 PSI.
Further, the edition of the code can play a role as well. If this particular vessel was fabricated in 1995 to VIII-1, then Turbo777's response is incorrect.
But... It could be a Section I vessel, it could be Section III (ok, I kind of doubt that), could be Section XII, could be Section VIII Div. 3 (ok, I kind of doubt that as well).
Or... it could be AS 1210, GOST, PED...
We just don't know given the info provided.
jt
LSR is essentially a factor that takes into consideration how much stronger the material is during a hydrotest compared to at its design temperature.
You have to go through each component in the vessel and divide the allowable stress at your test temperature by the ASME allowable stress at design temperature (230°F). The LSR is your lowest ratio calculated for all components.
As weldstan points out, SA-516-70 maintains its full strength for quite a while (it's actually at full strength only up to 500°F in ASME 2013), so the LSR is 1.
Cheers,
You may need a 1.5 multiplier, rather than 1.3. It depends on the edition (year) of VIII-1 to which a particular vessel was built.
When verifying LSR, don't forget to also check other components - you likely have a bit of SA-106, SA-105, etc. These may govern.
jt
The original post does not state new or in-service (despite requests for clarification) - and as I'm sure you'll agree, no AI or fab shop guy would ask this question. Thus, the very real possiblitiy exists that this is relating to a repair or alteration of a vessel in the field. Rumandcola does not assume "new", and weldstan mixes new and old.
weldstan- As marty007 points out, you are mixing pre- and post-1999 info. You don't get SA516-70 with constant stress up to 650°F and a basic stress multiplier of 1.3.
jt
