What are the Core Engineering Skills?
13
Hi Guys,
I have been asked to prepare a presentation 5-10 slides with the topic: "What are the core engineering skills?".
I was wondering if I could get your opinions as this forum obviously represents a wide range of engineering fields and disiplines and I may pick up on some areas that I'm missing out.
I was going to take 2 slides for the title/end & references, 4 slides for technical skills and 4 slides for soft skills etc.
Thanks in advance
Steve
RE: What are the Core Engineering Skills?
Just a start:
- Teamwork
- Logical Thinking
- Planning
- Organization
- Leadership
- Materials
- Electronics
- Chemistry
prognosis: Lead or Lag
Communication is number 1 - In writing, drawing, listening, and speaking.
Activate Brain.
Use Brain.
Listen first.
Communicate later.
Mike McCann
MMC Engineering
Logical thinking
Commitment (when you graduate, you have only started learning)
Mathematics
Communication
PE, SE
Eastern United States
"If a builder builds a house for someone, and does not construct it properly, and the house which he built falls in and kills its owner, then that builder shall be put to death!"
~Code of Hammurabi
Slide 1: LEARN HOW TO THINK!
Slide 2: Thank you for listening.
Troubleshooting - a logical, systematic search for the source of a problem so that it can be solved, and so the product or process can be made operational again.
A very strong BS detector - a lot of times instruments, people, and computers lie! You have to be able to catch those.
Good luck,
Latexman
Technically, the glass is always full - 1/2 air and 1/2 water.
I'd say mechanics is a pretty important topic. Same goes with som basic electrical skills, some software engineering skills even if that might be harder to explain in just a slide.
But most of all, I think the main skill of an engineer is to break down huge problems into small parts to be able to solve it. So, depending on what your audience is, I'd start with a big problem containing all the above mentioned topics in slide one and then show how to break down it into small parts after which you can solve each part using mechanics, maybe an iterative while-loop to illustrate software engineering and some electrics in the end.
+to Listening First, and ask good questions.
You cant fix a problem if you don't collect lost of information, decipher what it fact.
Curiosity
Problem solving
Reading comprehension
Mathematics
Critical thinking
Playing well with others
Courage of convictions
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies to make the best use of these Forums?
Add self-criticism to all the above.
A.
Pay attention to the details.
Know when to say you don't know.
Learn from the mistakes of others.
Try not to make mistakes.
Do not make a mistake that you have already been made aware of.
(Sorry, "try" just doesn't count for much on that last one.)
- Humility and respect to mother nature.
- "First don't harm" attitude with mother nature (corollary to the 1st one).
- Intellectually indendant as far as reasonably possible (human ressources is not your friend)
- Willingness to learn. Triumphed over his ego.
- Parcimony in drafting solutions or concepts.
- Skeptical. Initiate / Build models and test bench to test them empirically. Acknowledge cognitive limits.
- Not overconfident in science, i.e not arrogant.
- Act in accordance to his science and knowledge.
- Pursue a science which benefit and improve him first as human being (corollary to previous one)
- Can apply mathematics as tool if required.
- Hard worker (average 60 hours/week)
- Give attention to other people/peers, actively seek feedback.
I must confess to being a teeny weeny bit arrogant and rather confident. And I am paid for 38 hours a week, so guess what, that's what I work. Sure, if something needs finishing this week, it'll get done. But don't expect me in the office next week.
Cheers
Greg Locock
Core skills and attributes of an engineer:
- analysis: as the word's roots imply, the ability to break complex issues down logically into manageable pieces
- reason: the conscious application of logic to solve problems
- observation, i.e. generating data from the cloud of rubbish that usually surrounds an unsolved problem
- application of the scientific method
- knowledge of, and ability to apply, the underlying scientific principles specific to the discipline: at their roots, these are physics and chemistry
- dealing with uncertainty
- communication
- practicality and pragmatism: particularly, understanding when to guess, when to calculate and when to measure
5
Wow, I'm surprised that so far, nobody has included the main item I was taught. "Make a decision". Thats is what Engineers are paid to do. Use the math and science they learned to evaluate a situation, then make a decision on the next course of action. I see it everyday at work. Engineers who cannot make a decision are pretty much useless. Ok, I do appreciate the new Engineers who seek guidance of those more experienced, that is good. But in the end, I expect them all to make a decision and recommend a course of action to their boss. Not just ask their boss what to do.
bcd: well put. Being able to make a decision at the end of the problem solving exercise is key, and part of what I'd call being practical and pragmatic- knowing when to stop analyzing, observing etc. because you know enough to make a decision you can stand behind.
In no particular order:
- Humility (you must constantly admit how little you know)
- The ability to keep your mouth closed and listen, and to care enough to absorb information
- Dedication and Perseverance
- Grit
- Some type of passion (could be for any number of subjects)
- Common Sense
- The ability to pick out fine details but also make large scale assessments of problems (pick out what is critical!)
- Know how to handle STRESS in more ways than one. DON'T PANIC
- Know your resources and make good use of them (every engineer stands on the shoulders of everyone in their field that came before them)
- An appreciation for the old methods.
- A healthy skepticism.
- Embrace your responsibilities and obligations.
No. 1- Understanding that your primary function is to make sure your work output produces a profit for your employer in return for the salary you are paid. If you are producing a net profit for your employer you are an asset, if not you are a liability.
Nothing else really matters. So do whatever you can to make yourself an asset to your employer, rather than becoming a liability.
3
No.Number 1 must always be "Remember your obligation and the prime ultimate duty of care to the unsuspecting public."
There is plenty of room for the profit motive at #2.
1. Love of what you do.
2. Approach problems as if they were your problems, not the client's. You will always come up with the better, safer, solution.
3. Think of it as if it were your money, not the client's. You will always come up with the most cost effective solution. Remember, necessity is the mother of invention. When you do look at it as your money, you will develop critical and creative thinking.
And I love the one who said "Make a decision" above - in street English: "put your money where your mouth is".
i don't use next to no mechanics/ math at work (to those above that mentioned it)
Able to communicate
Able to learn, relearn and unlearn - Life-long learner
General knowledge of math & physics
Specific knowledge related to your field
Able to reach a conclusion when data is available
Able to make a decision when data is insufficient to reach a conclusion
The ability to make defensible assumptions so that a decision can be made.
Depending on the consequences of failure, the ability to handle the pressure of being wrong (I make jet engine parts, and could kill 500 people at once, if the 747 misses the apartment building at the end of the runway.) Some people called this confidence with a mixture of respect for Mother Nature/humility.
Doug
Personally, I feel that the "skill" most important to my professional development and work is resourcefulness. If you know what you don't know, you'll be ahead of most know-it-alls already. Support that with resourcefulness - knowing where to find the support, information, data, calculations etc. - and there is very little you should encounter that is entirely out of your reach.
A wise man once said, "A man's grasp should exceed his reach." Great, you can calculate the resistance of resistors in series... So, you'll freeze when you see resistors in parallel?! No. Go beyond, know where to look and who to ask; chances are, someone's been there before!
LiftDivergence summed it up too: every engineer stands on the shoulders of everyone in their field that came before them.
1) Preventing, proscribing, catching, eliminating (as well as cajolling others out of their likehood to cause): DEATH, INJURY, FINANCIAL LOSS, and all other forms of Real Property TORT on the unsuspecting public.
2) Getting paid for 1.
