Welding 4130 tubing to 304L rod
Thank you.
Is there any one out there that would know about welding 4130 tubing to a solid 304L rod will it work under hi impactloads?
Any ideas will be welcome. Thank you. DD3
RE: Welding 4130 tubing to 304L rod
The problem with welding 4130 to stainless steel, is that 4130 likes to be post weld heat treated (sometimes it is not done for very thin pieces) especially if you want good impact properties.  However, the 304L doesn't like to be heat treated (at least not at the same temperature).  It can form carbides and intermetallic compounds depending on its composition and the temperatures involved.  The easiest way to address the problem is to overlay the 4130 with a materail that can be post weld heat treated, then weld the overlay to the 304L rod without post weld heat treatment.  The most common filler metal for this type of application is NiCr-3 (Inco 82) for wire, or NiCrFe-2 (Inco A) for SMAW.  This filler metal has good toughness also.  For more detailed information, your best bet is to talk to a supplier who is familair with this type of welding so that all aspects of your application can be considered instead of the minimal ones that can be posted here.
