MathCAD background image
Can you do a background image on every sheet of you MathCAD file. Smath allows us to do this but it does not have near the capabilities as MathCAD. See attached image from SMATH. This is our image is on all of our paper so I want it electronically on all MathCAD sheets
Dallas Maughan
Structural Project Engineer
ES2
RE: MathCAD background image
structSU10 was correct about placing images in the header and footer of the files. The only difficulty that you may encounter would be determining the proper size image to insert into the header and footer regions, other than that its as simple as inserting an image in Microsoft Word. I've attached a blank template that we use at our office for your reference.
Dallas Maughan
ES2
or at a postion relative to the text on the page ??
you can always embed your page border onto your MathCad sheet directly (i've seen it done ... must've taken a month of sundays!?)
I also like the olde school way ... print your page border in Word, then print your Mathcad on these.
or maybe just go with a header (if you use both header and footer now ... i can't open the image, 'cause my IE is, well, IE).
of course you could import the Mathcad image into Word ... even page by page ?
Quando Omni Flunkus Moritati
MathCad uses a fixed position on the page. You have designated regions in the header/footer (left side of page, center of page, right side of page) that you can place an image in. You do have the option to modify location of the image vertically on the page by modifying the depth of the header and footer block however that is pretty limited as well.
As far as embedding the page boarder on the MathCad sheet directly I cannot speak to that.
TTFN
