Use of WB 36 pipes for boiler application
Does anybody has information on the use of WB 36 (Werkstuff no. 1.6368) in boiler application?
RE: Use of WB 36 pipes for boiler application
Actually this material can be found in SA-335 as grade P36 but accepted for boiler use only via referred Code Case. And advantages of using this material are not so big as when EN-standard is followed because of ASME's higher safety factor to tensile strength.
