High speed auxiliary lubrication pump
I need a auxiliary lubrication pump for a an aftermarket turbocharger. I need 15lpm at 1.5bar at 3000rpm and the ability of the pump to go up to 8000rpm. The engine uses a gerotor pump already but it is not even close in capacity. Is there a manufacturer anyone could point me in the direction of?
RE: High speed auxiliary lubrication pump
Ted
