click ok to termiante
While on opening an assembly in CATIA, am getting below message and the session terminates. We have increased the space available in C drive, and also increased the page file size, but there is no improvement.
Please give a solution at the earliest possible.
This happens only for a particular product. Awaiting your replies.
RE: click ok to termiante
Sudhakarn,
Try turning on "Work with the cache system" in Options --> Infrastructure --> Product Structure --> Cache Management
Change your Chache Size to 2000 MB for starters.
Restart your session.
You may need to try opening the Product a few times depending on the size. As you open the product, the system will generate a CGR of every part and put all parts into Visualization Mode. To edit a part, or see any Geometric Data, you will need to put the part into Design Mode.
What OS are you running?
WINdows 7. Previously we were using windows xp.
