ABAQUS-Breaking Torque (rotating torque)
Hi All,
This is the application where bearing outer ring is tighted fitted with the housing.
I would like to calculate the breaking torque (rotating torque) of bearing outer ring when tight fits are used.
Could you please suggest suitable solution for the same.
