Bolt Hole Diameter Versus Anchor Bolt Diameter for Lug Supported Vessels
Hello all,
I am reviewing a vertical vessel drawing with four support lugs. The drawing specifies to use 1" diameter bolts with a 11/8" anchor bolt diameter and I wanted some feedback if this is reasonable. Is there a standard table of bolt hole diameters for particular bolt sizes used in a lug supported vertical vessel in the ASME BPVC? Or is this more of a standard set from company to company? Any input would be greatly appreciated.
RE: Bolt Hole Diameter Versus Anchor Bolt Diameter for Lug Supported Vessels
Cheers,
PressureVesselEngr
