How to get the output of the abc-to-dq transformation isolated?!
I've a circuit built on simulink which is presenting 2 errors like the ones on the images bellow. This two errors appears to be related with the dq signal of the block "abc-to-dq". Probably I cant use a Demux to work with this signal. Can someone tell me how can I get the isolated components of the abc-to-dq transformation?
I believe the problem is that Iabc it's a electric signal while the demux is a block that must receive a vector. How do I solve this?
RE: How to get the output of the abc-to-dq transformation isolated?!
xnuke
"Live and act within the limit of your knowledge and keep expanding it to the limit of your life." Ayn Rand, Atlas Shrugged.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
