question about update wave-geometry
Hi
I have a question about how update is triggered.
exmpl no.1:
A single part named "def.prt" containing a datum csys and a datumplane placed 100mm at distance in X direction (or other geo)
this datum is copied via "WAVE" > "Copy to Geometry to Part" to another part named "geo.prt".
When I edited the datumplane in "def.prt" , and then go back to my "geo.prt" , I need to "Update for external Change",before my datum is updated to a new distance.
Is that working as desigend ?
exmpl no.2: If I apply the above 2 parts in a assembly - same level ,the datumplane is updated immediately when edited in the "def.prt" .
Should "def.prt"+"def.prt" part be put in an assembly, if immediately update is wanted ?
lklo
exmpl no.1:
lklo
RE: question about update wave-geometry
Anyway...
Having an assembly where they are both included is not needed.
If you wish to always have immediate updates, try setting your 'Assembly Load Options' so that the 'Load Interpart Data' option is toggled ON and the 'Load Parents' is set to 'All Levels', but again this can a bit of overkill as well.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thank's for your quick answer . My NX ver. = 8.5.1.xx .
The setting's you mention ,am I always aware about, and they are set as you suggest in this case.
But in the meantime , I have tried the same example in a NX 8.0 Version , and now it work's. (as I and you expected it should).
But NOT in NX 8.5.1.xx .
Can I get you to do a very simple test in NX 8.5.1.xx ? of cource -only if you have the time for it....
lklo
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
It is not possible for me to public prt files form my site SPW ( law ).
I have done a avi file (60mb) recorded in NX , which show the problem.
But I cant upload it - I dont know why.
I have tried in avi and zip format.
I will return ,if I can get it possible for me to public a prt.
But I dont think it is possible in NX8.5.1.3 to :
create new part "def"
create datumplane dist = X100
wave - copy geometry to new part "geo" - select datum located at X100
open "geo" part and just verify linked datum
go back to "def" part and edit datúmplane located at X100 to new value X0
go back to "geo" part
linked datum is not updated to new position
Works 100% in NX8 and NX9
lklo
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
www.nxjournaling.com
Thanks for your comment's . The 8.5.3 is also problematic in this case.
But I will look forward to the day we implement NX 9 .
(I´m newly employed as NX supporter in a company which has started up a transistion from Inventor to NX.
500+ users !!!! = lot of Work.
lklo
I'm currently working with some links in a somewhat similar situation (NX 8.5.3), but I do not have to use the "update for external change" command. The links update instantly and automatically.
In my case I have 2 parts without being components in a assembly.
Is that similar your case ?
If I add the 2 parts as components in an assembly - the update is triggered immediately = OK
lklo
Now I understand you are a Little confused about my case . Me too ,now !!
I have just tried to reproduce the case on my local course laptop , also NX 8.5.3.3 , everything is fine.
But in our production environment (also NX 8.5.3.3) it will not be done as expected.(as mentioned in my first question yesterday).
Load Interparts + All levels + No delay in both case.
lklo
