"Search" with a computer having two storage drives
I have new computer. There are 2 drives, primary one being SSD and the secondary being the usual magnetic disk.
When I "search programs and files" , only those located in the primary seem to turn up. How to fix?
RE: "Search" with a computer having two storage drives
TTFN
Mike Halloran
Pembroke Pines, FL, USA
This is WIN7, and search has been totally dumbed-down. There are no choices whatsoever. You merely type in what you are looking for. grrrr...
Ooops - my bad...
I should have clicked on "See more results"....then I see the directory choices .
Thanks, problem solved.
