Urgent issue in Kinematics
hi,
I have an urgent issue in Kinematics in an four bar mechanism Please help me out. I want to define a law with the below formula :
theta = theta1 + omega * t + 1/2 ( alpha * t^2 )
where theta is the fundtion to be measured
theta1 = angle at the starting point.
omega = ang.velocity of the bar ( 4 deg/s )
alpha = angular accelaration ( 1 deg/sec^2 )
t = time
this is a four bar mechanism and we are trying to measure the speed and accelaration of the slider in this mechanism.
The issue is CATIA is not recognising the formula when we try to simulate using laws.
Awaiting your reply at the earliest.
RE: Urgent issue in Kinematics
you have to define
theta1 as angle
omega as pulsation
alpha as angular acceleration
then feed the equation like :
Theta1 +omega *Mechanism.1\KINTime +alpha *Mechanism.1\KINTime *Mechanism.1\KINTime
et voila:
Eric N.
be carefull about the unit define in tools options general parameter and measure / units... default pulsation or angular accel might not be in deg per time (square).
Eric N.
thank you so much for your immediate posts.
