Analysis Discussion: HSS Baseplate, usually assumed as pinned. Yet in my FE analysis it seems Fixed.
Greetings, attached is a summary of my FEA analysis.
I am currently designing a two story OMF building. My initial assumption was to assumed the columns pinned at the base, I did this because it seems to be the common practice. But now that the time has come to design the base plates I'm having problems (cant sleep) simply assuming its pinned and designing it solely for axial force and shear (using AISC's DG1), it troubles me that if this connection is actually fixed (or at least with high rigidity) the baseplate will fail.
Now, I've always had problems grasping the concept of steel connection design; some people say that since you assume is pinned and you designed for axial loads only then it will behave as such. I proceeded to do a FE model, if the connection is indeed pinned then I should see little (no connection is truly pinned of course) moment being transferred to the baseplate. What I get is that the base-plate bends considerably due to the moment, now i would expect this since it is precisely this bending which allows rotation; however the stresses in the plate are much higher than what it can resist... So while it rotates, it seems to me that it would fail too. Now i proceed to increase the baseplate size so that it can resist the stresses, now the rotation is much much smaller... giving me the impression that by increasing the thickness I have made the connection rigid.
Please see the attached summary as it is much easier to understand. The initial baseplate designed for axial load only is 1cm thick, while the one designed based on the FEA is 2.3cm thick. I added results for more thicknesses to study the behavior, with 5cm thickness the rotation seems very low.
I don't really know how to judge if the connection rotation is high or low, or whether it approaches rigid or pinned behavior. I'm getting rotations of 2 degrees for the 1cm thick plate and around 0.5 degrees for others... is this a lot? is this rigid?. How much should a connection rotate in order to be considered as pinned?
Thanks and I hope you can help me with this dilemma.
RE: Analysis Discussion: HSS Baseplate, usually assumed as pinned. Yet in my FE analysis it seems Fixed.
In fact, one was 11 stories tall. and was built about 1986. It is fine to this day. We did not have FEA on computers back then where I worked. We had a simple 2D frame analyzer that ran on a strange "micro-computer".
If you run it as 100% fixed base, than your moment maxes out as the rotation is zero.
Now when you run it FEA, that may create a false impression of localized high stresses because I am assuming this a linear FEA analysis. Also, the more you thicken the base plate, then you are increasing the bending moment in the base plate as it approaches that theoretical 100% fixed condition.
I found this classification system for connections and would like to hear your thougts:
Link: Starts at bottom of page 46
http://books.google.co.ve/books?id=J3SJsyhpLBwC&am...
It says that if the connection moment capacity is lower than 25% of the fixed end moment capacity then the connection is pinned. How could I apply this to my baseplate situation? basically i would like to come up with a criteria that allows me to say if the connection is pinned or not.
I supposed i could model the frame with fixed restraint at the column base.. this would give me the fixed end moment capacity when i perform the analysis. Here is the part i dont understand... say I design the baseplate to have 0 moment capacity.. very thin plate... according to this it would be pinned... yet when the structure is loaded would the plate not yield and tear due to the moment.. and should a FE analysis not show you no moment at the baseplate?
Thanks.
My problem is that.. true i can run the analysis with pinned ends.. i get no moment at the base.. then i detail the baseplate with four bolts and the thickness for the axial load only... is this supposed to make it so that the baseplate takes no moment in real life?
You are overthinking this. If you had only the AISC code book, your frame designer software, and no FEA, you would be OK with this.
Besides, the rotations we are talking about are very small. The columns bases are not rotating very much according to your output, right?
Be careful... Modern codes and methodology have allowed our modern world's construction methods. Very few buildings have survived from before modern codes (gravity codes in 1910s & 20, seismic with a reasonable middle step from the 30s to the 60s). I do a great deal of work on historical structures, and not a one could be built today without losing your shirt. There is a good reason for that: premium materials, expertly installed and finished BUT with tons of redundancy because so few knew what was really going on.
Shake your head, apply the codes correctly and fight to correct them when they become unnecessarily complex.
@CELinOttawa: Thanks; I might complain a lot about the codes and curse them for the many complexities they bring but I always follow them to the letter.
While right now im inclined to designed the base plates as pinned, I still would like to hear more from the community in the matter... specially regarding classification using the results i obtained.
As for your model, if you have the capability in your FEA program, animate the model. This will show you how the model is acting under load and you can tell if you have a modeling issue.
Just because you model something in a particular way does not mean that it will act that way in the field. Model it the way you expect it to react....don't model it then expect it to react to your model.
I am just wondering why you refer to the baseplate as HSS, and the printout says it is A36.
Also, why are you using a square tube for the column? Is it large enough? - I did notice a very large rotation in two cases.
Frankly every engineer should read "Wooten's Third Law" five times before being allowed to touch a computer.
I never design exclusively by PC, and I would not have looked twice at the output you're stressing over. That's *not* an insult; I am setting you a challenge: Look beyond the output, after verifying there are no errors. Every design I put out is checked to within 20% "back of the envelope" style before I ever believe the computer or sign and seal.
I recently received news that the floor in a wood residential structure that I had designed long ago was finished with 3/4" mortar setting bed and natural stone flooring - had never heard of that during the design. It weighed a lot more than the ceramic/porcelain/travertine flooring that is commonly used here.
Also we get a lot of instances where the roofing is changed from plain concrete tile to clay tile with buttered end joints (without notification to me) - I actually heard from a builder that a roof over a porte-cochere sagged noticeably, and he went in and installed larger beams without any legal action taken against me, so I was lucky that time, also.
If you design it as pinned, but some moment is actually transferred to the base plate, what happens? If you base plate yields is that a bad thing? I would say no. Yielding a flat plate in the weak axis is very predictable and ductile. You can do it many times for small strains without adverse effect. Sail3's recommendations are good. Base plate yielding is fine, anchor bolt failure is bad.
I think we will start seeing timber collapses of the nature of the occassional steel and reinforced concrete collapse we see now, but not for another thirty or so years (20 at an absolute minimum).
I never head of Wooten...that was interesting.
I have read Russell Fling's (Designer of 30,000 concrete beams by ASD elastic method) essay of why USD design is nonsense. That was good read. (But I lost my copy)
This allows you to estimate the defections a little better and also predict the moment distribution due to your detailing a touch better.
http://www.nceng.com.au/
"Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the Universe trying to produce bigger and better idiots. So far, the Universe is winning."
Oh, and frankly Wooten is the man. I mention the third law weekly, and daily if not hourly when training an intern.
I was hi-tech when I went to graduate school, however. My thesis was Progressive Collapse of Steel Frames.
I would love to read that as well; it sounds interesting. Do you remember if it was a stand-alone article or part of a book?
From school to school the quality of graduates varies much more greatly out of the US than out of most other countries with which I am failiar... As a result your codes tend to me even more "recipe book" than anywhere else. That holds back true understanding and lends itself to the comoditization of Engineering.
VERY good engineers (and quite sh*te engineers) exist in all jurisdictions.
We test and categorize the heck out of our High School students, but we don't know how to teach them math and science properly.
BTW - my HS counselor recommended to me that I don't go to college. Still trying to figure that one out.
The baseplate is A36, the HSS tube is a different steel (im not in the US, I dont know if HSS in the US is also A36). I use HSS because thats produced in my country, W shapes are imported so the price is very high. Here we use HSS for both beams and columns.
@Ron: I agree with you on structures not actually seeing the loads for which they have been designed. For example I would say that the 1.6 amplification on the live load pretty much guarantees that the live load will not be exceeded, unless of course the owner decides to change the use of the structure... say turn a second floor of a commercial building into a storage area.. that would be a big problem and indeed I have seen it happen; however I would say this is not a design error but rather a user error.
I checked the model and qualitatively it seems to behave as expected, I recently took a SAP2000 class that covered modeling baseplates and I based my model on this.
@Sail3: Thanks for such a thorough answer, I understand what you say about the redistribution of stress; my intention with the FEA model is to determine the connection stiffness at the onset of yielding in the plate; My understanding is that as the plate further yields and redistribution occurs the rotation of the connection would increase; thus a connection that behaves as pinned in the FEA model should approach such condition in real life. However I do feel uncomfortable not being able to model or predict this redistribution.. While I know that redistribution occurs I do not know how to calculate or estimate it. If anyone knows of a way to do this I would be most grateful.
@CELinOttawa: I agree with you, I also do not design solely by black box programs. In this case I am trying to better understand the behavior of the connection, in the past I have relied on AISC DG1 for calculations. I use FEA as a tool, I do not blindly accept the results; if I did we would not be having this conversation. If you have a "back of the envelope" method to quickly estimate connection stiffness and rotation I would be most grateful if you could share it.
@Gumpmaster: Thanks for your reply, I would pose the question how can I determine if there is too much yielding? There must be a method to ascertain this or at least to help in making an engineering call.
@rowingengineer: To be honest I have never designed a semirigid connection, my understanding is that you would need the moment-rotation curves for such a connection. In the past I have chosen connections that are widely assumed to be pinned or fixed. But I can see how such analysis and design would be better, specially since no connection is truly pinned or rigid.
@johnbridge231: I added springs to the area elements that form the baseplate, this springs are compression only and are very stiff to simulate concrete pedestal. The bolts are modeled as a pinned restraint; the loads are non-linear and the analysis is as follow: apply axial load, then use the matrix resulting from this load to apply the moment load.
We don't see A36 but rarely in the USA now. Most steel is Fy = 50ksi.
HSS means Hollow Steel Section, not High Strength Steel. Fy can be from 36 to 50ksi, for rectangular tube section, the 2 most prevalent here are 46 and 50 depending on the exact steel spec.
I am surprised you use so much HSS instead of W-section. Here, the W is cheaper and much easier to make connections. Plus, with HSS and you have a non-thru shear tab, the question is, does the tab buckle the wall of the HSS, or does it punch thru? Sounds like a can of worms.
I'm not trying to be smart... Most software will allow you to enter this value as a stiffness at a connection, and in hand calcs you can apply a moment based on the partial stiffness.
Whatever moment you develop at that point and are happy with, you design your system to sustain without failure (both SLS & ULS).
Thus is exactly the type of situation Wooten was envisioning: You will never know the exact state of stress, even with FEA, so pick a possible state of stress and design against that. Plastic materials WILL conform.
I base most of my calculations in the design guides provided by CIDECT, which is an european agency that promotes and research the use of rectangular and circular hollow sections. The top of the cherry is that the hss sections produced here are not compact and 90% of the country is under the risk of a seismic event. Dont try to convince anyone here to use a single bolt on their structure... absolutely everything is welded... the baseplate.. they weld rebars to the plate instead of using proper anchor bolts... The rebar manufacturer clearly states that they rebars are not weldable. Thank god that most structures in my city don't go over two floors, I studied my M.S in the US.. imagine my shock after coming back here and facing all this steel tubes beams and columns... even in universities here they teach steel design with only W-Sections... Its absurd.
Vietnam still uses Bassemer steel for EVERYTHING.
As I see it right now a column-baseplate connection fixity depends primarily on the thickness of the plate (supposing no stiffeners are used), a thin plate behaves as pinned because it bends considerably, causing the column to rotate and thus not gaining moment. Is this correct?
My dilemma starts here: Since I assume the baseplate to be pinned I size it solely for axial load, which results in a thin plate; But in reality the plate has to bend so it must have stress... If I assume there is no axial load how can I verify that the bending of the plate is not "too much"?
@CELinOttawa: I have done this before.. But how would this allow you to calculate the connection stiffness?. Or are you saying that the connection stiffness will be conditioned by the moment I design it with?.. say i model my frame for only 10% of the columns moment capacity to be transmitted to the base... I design the baseplate for this moment.. And since I designed it for this moment this results in a stiffness that will attract approximately only this moment?
Make the baseplate 3/4 to 7/8" thick. That is common for 2-story steel building.
So long as you have a stable state that provides sufficient Strength, Stability, and Stiffness, plastic structures will comply. It is effectively a close-cousin of the Hardy Cross Method (though I have no idea if you've learnt it, it is DEFINITELY worth learning about at a minimum).
Thanks, you've truly opened my eyes on this subject... And I can totally see how a FEA model cannot capture this behavior. I was taught the moment distribution.. which I believe is the hardy cross method... So I can see what you mean, however I never thought of applying a similar concept to the connection - member interface. I think my error is thinking of connections as a separate part of the structure.. a habit probably enforced by the use of "stick frames" software where connections are idealized as nodes.
Having established that FEA does not capture stress redistribution due to yielding, it would seem to me (feel free to call me an idiot if I am wrong) that it would still give a close to reality result for connections where no yielding is desired.. For example a fixed connection where i wanted to reduce rotation to the minimum.
@AELLC:
Thanks, I will aim for this during my calcs.
You are still too FEA-oriented...others have designed countless low to high-rise steel buildings without any FEA at all.
How many years since you got your degree at University?
I got my M.S in Civil Engineering 3 years ago, I have taken several classes and courses in FEA modeling of frames.. Im not saying this validates using or not using FEA for relative newbies like me.. just saying that I know what Im doing when I do a FEA model of a frame.
Actually, my first job was fixed offshore oil production platforms in the Gulf of Mexico, we had a sophisticated 3D frame analyzers for the underwater structure (jacket) up to the main deck about 100' above sea level, no FEA at all, and we did all the superstructure framing purely by hand. A lot of stuff with no Code guidance at all. BTW we only went by American Petroleum Institute code. That was in 1974-1975 and we were in only 350' depth of water then. The foundation piles went about 300' into the seafloor (mostly loose crud), and all the conductor pipes (piping for oil) went down thru the 2 large vertical legs of the jacket. The jacket had only 4 legs total, and the 2 were battered (sloped), leaning toward the direction of the worse hurricane. The 2 main vertical legs were always 64" dia and the 2 battered were always 48" diameter but we varied the thickness especially in the joint regions, they were much thicker.
You're not an idiot; You're learning... And you're smart enough to ask questions when you're not sure. That's a sign of intelligence, not stupidity.
SO: For a fixed/rigid connection, the model will only give you as accurate a result as your real world material is capable of conforming to with respec to the model. Remember, there is a whole lot going on in your section that we just "set aside" when doing design, ie: Metalurgical defects, fabrication errors, residual strains, etc. They are covered by our material reduction factors when designing in terms of strength, but they also have an effect on the actual (service) behaviour.
Your thinking is correct, just remember to think that you CANNOT model it at all accurately; You can only make enough assumptions and set up the conditions such that you can model and design SAFELY.
At three years out, this may still be of some help. You may not get the cultural joke, but a Canadian Intern would invariably find this something to chuckle at:
My personal rule to competent Structural Engineering is SSS DUCE.
Strength
Stability
Stiffness
Durability
Utility
Constructibility
Economy
At University, you had to model it ALL accurately for full credit. What I meant by "conditioning"
Virtually everything I have ever done was according to precedence ("go-by") - what about other completed projects in your office, are they similar, how was the baseplate treated?
@CELinOttawa: I understand, at least I can use this to better understand the behavior of some very non-standard connections that are sometimes required here.
@AELLC: The rule-of-thumb has been to design concrete columns as fixed on the base and steel columns without any stiffening as pinned on the base, for the base plates we usually design for axial load only, following the AISC Design guide. Using this design method the base-plate thickness for the current structure I'm designing is 1cm (about 0.4 inches)... Probably bumped to 1/2" since plate thickness is measured in inches here, having read yours and others suggestions in this post i feel inclined to take it up to 3/4". There is considerable shear on the baseplate, enough so that two bolts might not be enough. I might have to add a shear lug (not common here) or embed part the hss in the slab (they do that all the time here.. but by error.. the pedestal never extends above the slab on grade so they usually pour a 10cm slab on top of the baseplate).
@Rowingengineer: Thanks, I had read about this method before but I have never used it before I will give it a try.
I don't design in steel any more - it has been years, and I was working on memory - you are saying by calculation it comes to 1/2", that is fine if you are comfortable with it. Me, I would go to 5/8" or 3/4" because the cost increase is insignificant.
In "real world" at work, we are not calculating to get the "textbook answer" the professor is looking for, to get full credit on the test. We are doing things to save time and end up with a practical and cost-efficient answer.
Anyway, see attached procedure from the old AISC 7th edition here (ASD)
The definition of a structural engineer: overdesign by a factor of 1.999, instead of the usual 2.
We had to "code up" the structure on paper input sheets, and wait until the next day to receive a computer printout of results, many inches thick.
May advice on the base plate fixity:
Start with a pinned case - regardless of how the bolts and column are arranged. If you can live with the additional moments driven up into the column and the sway is under control, then you are on the right track. Why throw moments into a foundation system? It makes the design needlessly and meaninglessly complicated.
Now, if you end up with an unmanageable column size, or unpalatable sway, then you start looking into other options. Keep in mind that full fixity through a base plate, anchor rod, pier, footing system will be virtually impossible to achieve (except for a cantilevered system). Now you are left with modeling a system which takes into account partial fixity. Keep you method rational and reasonable conservative - it may take some trial and error to get the reasonaby accurate results you are looking for. Just because it is FEA-modeled doesn't inherently make it reasonable or conservative.
