copying bodies
copying bodies
Hello.
What's difference between "Extract Geometry", "Extract body here" and "Copy (within Move)"?
RE: copying bodies
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
RE: copying bodies
OK, you mentioned three methods for making a copy of a body (there are actually some others but we'll not confuse you with those for now).
Anyway, to the questions you've asked, I assume that the first two pertain to...
Insert -> Associative Copy -> Extract Geometry...
...where you've selected the 'Body' type. If you toggled ON the 'Associative' option in the settings section but NOT the 'Fix at Current Timestamp', the copy will always end-up as the LAST feature in the Part Naviagtor. In other words, once 'extracted' it will continue to update whenever features are added or modified. If you had also toggled ON the 'Fix at Current Timestamp' then the body that is extracted will NOT move when new features are ADDED to the model but it would update if any of the feature created before the 'extraction' were modified. Now if the 'Associative' option is toggled OFF, then by default it will be created at the current timestamp and it will not move when new feature are added the original model, and it will NOT update if older features are modified.
As for the Move Body using the 'Copy' option that works sort of like Extract without using the 'Associative' option. The only re difference is that you get to move the copy whereas in the Extract function the copy ends-up being the same place as the original.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
RE: copying bodies
I never considered usually the move/copy command, instead of the extract body command.
RE: copying bodies
I know Wavelink, but this is intended to be used between dfferent parts in an assembly.
What other methods are there that produce different or important results?
RE: copying bodies
This is not part of the Extract Geometry command. When you use Extract Geometry command, it will be created as the last feature in the Part Navigator. And according to the 'Fix At Current Timestamp' it will behave as JohnRBarker already explained.
Now, if you have already created your model and want to extract body in let's say step 3 of finished model, there is another story. With Extract Geometry, you would have to make this step3 as current feature and then use this command. But, with Nx8 (and later), you can do the following:
1. click with right mouse button on the step3 in part navigator.
2. from the menu, select 'Extract body here'
3. at this point in part navigator, the new body will be extracted. Just as if you would make this step current feature and then use Extract Geometry command.
So, the difference between 'Extract body here' and 'Extract Geometry' is, that the first one will save you clicks and time, when you have to extract the body in a specific timestamp of already created model.
I hope, that this explanation is clear enough.
RE: copying bodies
SS
CAD should pay for itself, shouldn't it?
RE: copying bodies
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
RE: copying bodies
(I'm not speaking of CAE analysis, only CAD).
RE: copying bodies
Now you can get very creative if you wish, as I've already alluded to earlier, where you could have several different variations and the Extractions could have been performed at various points along the 'history' of the model so that you could have different levels of 'common features' for each variation. Now it's critical that you have to use the option where these extractions are defined as being 'Fixed at Current Timestamp'. Once you've got what you want you can assign each variations to its own Reference Set so that when this model is added to an Assembly you can pick and choose which variation that you want to use, and since ALL of these variations are collocated in the same place and orientation in the master model, even if the Components in the Assembly were not constrained, you could replace one variation with another and there would be no chance that they would move or be oriented differently.
Now this does bring up something that people may have been wondered about.
Have you ever looked at the Part Navigator and wonder why there's a 'Timestamp Order', or to be more exact, why would you want to toggle 'Timestamp Order' OFF? Well this is one of those situations where this is handy, when there are MORE THAN ONE model in the same part file, which would be the case if you were doing what I described above. When you're not in the 'Timestamp Order' mode you'll be able to see all the variations and by looking at how the features are related to which body you can get a better understanding of how all the variations were created. Also, while you've in this mode, it's very easy to toggle the display of the various 'models' ON and OFF (Show and Hide) which makes it very east to go back and forth to work on the variations, as shown below:
Anyway, I hope that helps to explain one the primary reasons why NX has this capability of Extracting Bodies yet leaving them collocated.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
RE: copying bodies
