Re-Ordering Stacked Balloons
Is this possible yet? Any time you want to 'add to stack' - the latest balloon comes at the end of the callout. If you want to re-order a stack, is there a way to do this, without deleting the stack - and hitting the items in the proper sequential order?
SW Professional 2014
SW Electrical 2D/3D
64 bit SP1.0
Intel Xeon X(R) CPU 1603 0 @ 2.80 GHz
8.0 GB of RAM
NVIDIA Quadro 2000
RE: Re-Ordering Stacked Balloons
if the balloon is linked by the BOM Item No, you can reorder the parts in the BOM and the balloons will update.
Chris, CSWA
SolidWorks 13
ctopher's home
SolidWorks Legion
I'm not sure if it's possible from the UI... I think one could modify the code in
thread559-219586: Balloon order HELP SW2008 SP3.1
relatively easily to achieve a "move to end of stack" type functionality.
-handleman, CSWP (The new, easy test)
