Assembly hidden line associativity
We are looking to create the out line of one of our machines using the assembly hidden line tool but we want it to be associative. I set the view I want, initiate the assembly hidden line function, save the curves that I have extracted to a new part file in Teamcenter and saved the part. Now if I go back to the assembly and change the physical form of a component, or change the position of the component, I then click the update button on the assembly hidden line function and nothing happens. IS there something I'm missing?
Cheers
Si :)
Cheers
Si :)
Best regards
Simon NX 7.5.4.4 MP8 and NX 8.5 (native) - TC 8 www.jcb.com
RE: Assembly hidden line associativity
Now it is possible that perhaps you're confused by the use of the term 'associativity' in the user Help files. This is probably a poor use of words since in this case it's really just a way of 'referencing' which set of curves in the Hidden Line file come from what Component in the original Assembly. It was not used in the sense that somehow live links were established between this illustration file and the original Assembly or it's Components.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Best regards
