Define Render Sets
Define Render Sets
Define Render Sets
is there a way to execute a multi selection of solids when I created a set with DEFINE RENDER SETS.
I have about 154 solids to selects them
Version NX 8.5
tks
Edson
www.t-systems.com.br
RE: Define Render Sets
Have you looked at creating a Component Group containing the components where the solid bodies are located and then selecting that group when creating the Render Set?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Helo Mr Baker, tks for your help!!!
Yes I do, but the four items listed in the panel does not satisfy the selection.
Is it possible to create a group with the desired components?
tks
When you say "...the four items listed in the panel does not satisfy the selection." what "panel" are you referring to? If it's the list of Assembly Groups shown in the Render Set dialog, you need to actually create a user defined Component Group first which contains the solid bodies that you need to select.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
I try to create a component Group..
Thanks...
