Rebuilt CMU wall: top plate connection
Hi folks,
I have a house job where the entire retaining CMU wall needed to be rebuilt. Any recommendations for connecting the top plate to the rebuilt wall? The existing floor joists are only 2x8 so drill and epoxy would be hard, and there's a 4" gap where we'll have a solid block at the wall top to match the existing height, so poured in place rebar ties would be hard. We thought about strap ties wrapped around the solid top course and tied to the sill.
Any better suggestions? Thanks!
RE: Rebuilt CMU wall: top plate connection
If that's not possible, your specific problem needs a sketch.
The other option is to nail the sill plate with the bolts hanging into the bottom of the joists. Then, break out the face of the top course to go around the bolts and fill and form with mortar.
You could also make a connection from the face of the block to each joist with a piece of angle iron.
