ANSYS static structural help : Bodies Overlapping
I'm looking to make a model of Equal channel angular extrusion (pressing) using static structural in ANSYS. Something similar to the videos below.
http://www.youtube.com/watch?v=TsTjMXLmTao
http://www.youtube.com/watch?v=N1UUMGgZ8mM
I am having a hard time getting my deforming billet to follow the die path and not to overlap into the die body.
http://imgur.com/a/yGqd4 The second image here shows the deforming billet overlapping into the die which it shouldn't do.
Does anyone have any suggestions as to how to fix this?
thanks
RE: ANSYS static structural help : Bodies Overlapping
If you reduce the contact stiffness to aid convergence, and get a lot of penetration, and if the penetration is larger than the pinball diameter, I think the contact can exit the back of the target and release. And, ANSYS used to automatically reduce contact stiffness when plasticity was present. Not sure if it still does, I think there may have been a change recently. With no plasticity, FKN=1. With plasticity, FKN=.01, I think.
Rick Fischer
Principal Engineer
Argonne National Laboratory
