Measuring Distance Between Parts
I have an assembly which consist of nearly thousands of Plates(Parts).
I want to generate a report which consist of distance between the plates.
If the Distance between the plates is greater than 150mm it should be marked in a colour.
Report may be in xls or xml format
Plz help..
