Ground fault relay protection
I am coordinating a relay associated with a MV breaker with a LV breaker downstream for ground fault. There is an existing relay upstream of the new relay which has an instantaneous setting for ground fault but no definite time setting. My thought was to use instantaneous with definite time to not allow tripping below a 0.5 sec which is above the LV breaker curve. Any ideas on what best practise is?
RE: Ground fault relay protection
For the LV side, you need to coordinate with the any other downstream ground fault relays.
