Bond constraint
Bond constraint
I used this one recently but it did not behave as expected. I "bonded" a nut and washer to a bolt which was constrained to a hole in another component. When I changed arrangements the bolt moved with the part to which it was constrained but the nut and washer stayed in original position. The bond constraint is "shared" on both arrangements so it seems set up properly. Any ideas on why this is not working properly?
RE: Bond constraint
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
RE: Bond constraint
RE: Bond constraint
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
RE: Bond constraint
I have a long arm of multiple parts, which are moved by hydraulic cylinders. Near the cylinders there are some hydraulic hose couplings floating in the air, just to make the bom list complete.
I have bond the hydraulic hose couplings to the arm, but the couplings are not moving with the arm in other arrangements.
Using NX 8.0 and Teamcenter 8 on Windows 7 (64)
RE: Bond constraint
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
RE: Bond constraint
RE: Bond constraint
RE: Bond constraint
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
