Structural Design of Grouted Ripraps/Concrete Slope Protection
Generally, we design structures that serves as "Soil Retaining Structures" to resist soil pressures, including earthquakes, that's why we came up with gravity walls, cantilever walls, sheet piles, etc.
Also, we use ripraps, concrete slope protections, rubble concrete sometimes with a thickness of 0.2 to 0.5, with specified slopes, to "retain" the soil, or practically for erosion control. The main factor in designing this is the hydraulic velocity.
Now, correct me if i'm wrong, so practically structures such as ripraps/grouted ripraps, are design to prevent soil erosion from effects of water current from rivers, not from the effects of soil movements?
Also, what is the purpose of using grouted ripraps for specified slopes on embankments? How are they analyzed?
How about sheet piles or other piles with pile caps connected to inclined grouted riprap or concrete slope protection? How are they designed?
Slope stability?
Thanks in advanced!
Slope stability?
Thanks in advanced!
RE: Structural Design of Grouted Ripraps/Concrete Slope Protection
I knew (from my boss) that generally a slope with 45 degrees is practically stable, but still depends.
Very Truly Yours,
- andru18
Rip rap can be used to increase buttress at the toe of a slope, which would return an increase in the overall "global" safety factor.
Grouted rip rap will act as a hydraulic barrier. If it's on a 1:1 slope in short order you'll get fairly high hydrostatic pressures if/when water builds up on the land-side of the grouted rip-rap. That could be (is?) a bad thing. So, you'd have to consider weep holes or some other such method to allow equilbration of water pressure.
f-d
¡papá gordo ain’t no madre flaca!
