Upper case letters and spaces in File Names
Are Upper case letters, spaces and long File Names against NX's best practices?
Michael Fernando (CSWE)
www.solidCADworks.com
Tool and Die Designer
Siemens NX V8.5 + PDW
SWX 2013 SP3.0 X64
PDMWorks 2013
Logopress3
FastForm Advance
FormatWorks
RE: Upper case letters and spaces in File Names
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
you might find some situation where spaces aren't accepted or the usage of them makes life more than necessary difficult.
Tomas
Do you see it as an issue within NX or externally like in at file translations or at integration with third party software?
Would you be able to give some instances or share some of your experiences please?
SWX 2013 SP3.0 X64
PDMWorks 2013
Logopress3
FastForm Advance
FormatWorks
www.nxjournaling.com
Tomas
SWX 2013 SP3.0 X64
PDMWorks 2013
Logopress3
FastForm Advance
FormatWorks
I'd suggest contacting your IT department and asking for their input.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Don't get your hopes up that setting it to UPPERCASE will enter all text typed into NX to be converted to upper case, like in notes which are required to be in upper case when on the face of a drawing. You will still need to use the Caps Lock key for that.
Ben Loosli
