Mystery File - Inventor 2011 Pro
Hi All,
For some unknown reason in some of my assemblies I'm getting the following file - 990-20.ipt - that cannot be found. If I skip the file I get an Unresolved Assembly. I have done a complete search of every component in the assembly and cannot see it, I've even done a file search through Windows Explorer - the file does not exist.
Can anyone assist with this please.
Best Rgds,
Dave R.
Best Rgds,
Dave R.
RE: Mystery File - Inventor 2011 Pro
Inventor has already told you it is unresolved. How could you see it if Inventor can't "see it"?
I am not even sure what you mean.
Is there a grayed out node for the part in the assembly component browser?
Delete the node.
Rgds
Dave R.
At the first you have to find the assembly unit or derived part that uses your missing file. This you can make when opening assembly and prompted to skip missing file. On that window somewhere you will see the path and name of the subassembly or derived part.
Maybe Inventor is Inventing things to try me out!!
Rgds,
Dave R.
