export dxf of NXdrawing containing symbols in the titleblock fields
hi
I have som problems , when I export a dxf file of a drawing in NX.
Almost every thing is OK , but the fields in the tilteblock is empty in the dxf file ,if I open it in Autocad.
Not all fields are empty .
Only theese that is populated with a Company standard - (could be a symbol or other non text.) - failed
The cgm translator IS able to handle theese symbol's ,if I used this method , but I would like to avoid the cgm method , if is possible.
question: is it possible to modify the dxfdwg.def file , so it can handle symbols or other non text in the titleblock (tabular notes)?
lklo
lklo
RE: export dxf of NXdrawing containing symbols in the titleblock fields
I used the dxf/dwg wizard .
lklo
lkl
