API Pipe with ANSI Fittings
I am currently designing a pig launcher for a customer. It is a 16 to 12 inch pig launcher, and i selected API 5L Grade X-52 SMLS Pipe for both the 16" and 12" line. My problem I am having is the flanges that are attached at the various locations on the pig launcher are of ANSI Specs. The differences between the API Pipe and ANSI Pipe Nominal is creating small differences between the two. Is it acceptable to use ANSI fittings with API pipe?
Thanks!
Thanks!
RE: API Pipe with ANSI Fittings
All other flanges for nozzles not part of the connecting flange can be more normal material.
