Hand-calculate Moment Area of Inertia
For a truss, do I include only the bottom and top chords, and ignore any truss webs?
RE: Hand-calculate Moment Area of Inertia
I would. The webs will contribute, but not much, therefore you'll be slightly conservative. I look at truss chords as similar to the flanges on "I" section beam.
There was something I forgot about, brought up by someone else's reply in a related thread I started .
Shear deformation ... seems to significantly increase the actual deformation, maybe as much as 20%.
I just was speaking to Simpson Strong-Tie, and by "accident" they mentioned they are starting a truss design division.
I asked that the "nerd-in-charge" (j/k) give me a call so I could ask him what science and assumptions the software uses.
They bought keymark software a year ago
Back when I used Keymark software around 1990 it was not good. They pretty much faded away, as far as I could tell. I didn't know they were even still in business.
Well, if Simpson is using it, than that is not good.
