Change Time Interval in Paired Data of HEC-HMS
New to the forum, did a quick search and didn't see an answer to my particular problem.
I'm using HEC-HMS 4.0 and I'm trying to input a user specified unit hydrograph. The time interval is set at 15min, but my data is at 1hr intervals. HEC defaults to the 15min interval and I can't figure out how to change it. Please help.
Thanks.
-Bill
RE: Change Time Interval in Paired Data of HEC-HMS
Bill,
You might be able to use a Discharge Gage in the Time-Series data which will allow you specify the time interval of your choosing and specify the associated discharges.
Hope this helps. Good luck.
Components/Time-series data manager/Precipitation gages/new
Then
In the Times-series Gage you can specify the Time Interval from 1 min to 1 day.
Then enter it in the Table.
Thanks for the tips everyone, I ended up just interpolating the data I had to 15 min intervals.
