Extracting Centerline of dumb cable solid
thread561-257837: Cable Center Spline
Hi John ,
Is there any program or journal which would extract the centerline for a cable whose outer surfaces are created by B Surface.. I had one journal file which I had downloaded long time ago from your postings, but that does not work on B surfaces..
NX8.5
Any help is appreciated..
Hi John ,
NX8.5
RE: Extracting Centerline of dumb cable solid
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Here is the sample part..
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
thread561-331345: Centerline extraction at a system level in NX
www.nxjournaling.com
Please can you try now?
Iam unable to attach the sample part.. Please help..
If the outer surface is a B surface, the journal does not extract the centerline..
I know this one works for B-surface tubes, I've used it myself.
The tubular surface is not co-planar.. So when I run the program, it gives me some random spline which is not a centerline..
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Here is the step file..Iam running NX8.5.3
