Remove Interfering Volumes
I have a woven mesh molded into a part. I have it visually modeled by simply putting the mesh inside the part and making the part transparent, but I would like to remove the volume of the mesh from its overmold so that I can have accurate numbers in my model.
Is there a way to remove this interfering volume from my overmold?
RE: Remove Interfering Volumes
allow_ref_scope_change YES
default_ext_ref_scope ALL
default_object_scope_setting ALL
default_object_invalid_refs COPY
ignore_all_ref_scope_settings YES
model_allow_ref_scope_change YES
scope_invalid_refs COPY
edit/component_operations/cut out
then selecting the over mold, and then the mesh.
Again, this is after I did everything you guys told me, so it may have all been necessary. But a standard trim/merge tool would not work.
