corrosion of steel sheet pile in clay soil
I am searching for a reasonably simplified equation for computing the approximate rate of corrosion of a steel sheet pile (A572, Grade 50, 1/4" thick). I have groundwater chemistry information, including the pH, sulfates, chlorides, alkalinity, and conductance. The upper section of the sheet will be above the groundwater table and the lower section will be below the permanent groundwater level.
RE: corrosion of steel sheet pile in clay soil
