Vacuum Pump not proper functionally
Recently impeller of vacuum pump is broken of an autoclave (chamber capacity 550 liters), Materials of impeller seem to be gunmetal therefore i make the impeller as per sample by gunmetal. But vacuum performance is not good. i require 115 mbar but only get 500 m bar
i have checked the vacuum seal , leakage around the piping
RE: Vacuum Pump not proper functionally
If you made the part it is probably not to correct design / dimensions. Suggest you purchase a genuine part.
can anyone help me to how to design the impeller of vacuum pump.
Is there a reason you are ignoring Artisi's suggestion?? Seems like look advice to me
If you're determined not to follow Artisi's advice and buy a new OEM impeller, it would be easier for you to design a new complete pump.
