Object Count of Layer
I am confused, could someone please help? I have a component(X2) that contains surfaces on different layers. That component contains another component(X10) that was used for reference only. When I go to my "Layer Setting" the "Object Count" for layer 7 is including items from X10 where as layer 6 does not. Layer count should be 1 for both layer 6 and 7 but it is showing 6 at 1 and 7 at 2. This is with X10 closed. I thought there where objects in X2 that I just couldn't find or display so I used the program below to clear layer 7 but it deleted X10 from tree.
Can anybody explain this for me?
Kevin
NX8.0
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpenUI
Module delete_all_on_layer
Sub Main()
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim layerObjects() As NXObject
Dim UserInputNumber As Double
UserInputNumber = NXInputBox.GetInputNumber("Enter Layer You Wish To Clear", "Layer", 0)
'clearing layer "X" of all entities-------------------------------------------------------------
layerObjects = workPart.Layers.GetAllObjectsOnLayer(UserInputNumber)
If layerObjects.Length > 0 Then
Dim count As Integer = theSession.UpdateManager.AddToDeleteList(layerObjects)
Dim undoMark As Session.UndoMarkId = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Undo Mark")
theSession.UpdateManager.DoUpdate(undoMark)
End If
End Sub
End Module
Kevin
NX8.0
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpenUI
Sub Main()
End If
End Sub
End Module
RE: Object Count of Layer
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Yes, X2 is a temporary assembly and yes, the layer list for the assembly. Once all needed geometry is created in X2, X10 will be deleted from X2 because it will no longer be needed for reference.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Kevin
