color palette
color palette
color palette
I have to open more than 100 part and change the color palette (i just have the right .cdf) of every single part,
because when i export a STEP of the entire assembly the color is take from the single part.
The costumer want the right color for CAM purpose.
nx7.5
win 7 64b
RE: color palette
We use hypermill for CAM and had a hell of a time getting the correct colors to translate.
We had to modify the color pallet in hypermill as well as the UG color pallet to have the correct color number come thru.
It was more that the correct color number and not the actual rgb values matched.
So if in UG you had color 114 assigned to a surface you wanted it to be color 114 in your CAM software.
We ended up using parasolid since our CAM package supported parasolid.
STEP and IGES kept giving us grief with the colors.
I still have a lot of issues getting UG and Catia to translate the same colors between the two systems.
Jurgen
NX8,8.5,9.0
RE: color palette
I have found a way to solve this problem force the rgb color in NX
for example this is a part of my cdf file
blu 0.3725490 0.3725490 0.6862745 52
Pale Weak Magenta 1.0000000 0.8000000 1.0000000
Pale Weak Red 1.0000000 0.8000000 0.8000000
Pale Dull Orange 1.0000000 0.8000000 0.6000000
Light Orange Yellow 1.0000000 0.8000000 0.4000000 38
Light Yellow Orange 1.0000000 0.8000000 0.2000000
Yellow Yellow Orange 1.0000000 0.8000000 0.0000000
Pale Weak Blue 0.8000000 0.8000000 1.0000000
Pale Gray 0.8000000 0.8000000 0.8000000 15
Light Weak Yellow 0.8000000 0.8000000 0.6000000
Light Dull Yellow 0.8000000 0.8000000 0.4000000
Medium Faded Yellow 0.8000000 0.8000000 0.2000000
Dark Hard Yellow 0.8000000 0.8000000 0.0000000
Pale Dull Azure 0.6000000 0.8000000 1.0000000
arancio chiaro 1.0000000 0.6862745 0.0000000 57
the "blu" and the "arancio" .
was set by in true RGB by my (if you need i can show you how)
The problem is that i have make a mistake with only one of those color.
PS I make this conversion for a customer with catia.
