how to remove this error Unable to load DLL 'libpart': The specified module could not be found.
i have use this code
using System;
using NXOpen;
using NXOpen.UF;
using System.Runtime.InteropServices;
public class Program
// class members
private static Session theSession;
private static UFSession theUfSession;
public static Program theProgram;
public static bool isDisposeCalled;
// Constructor
public Program()
try
theSession = Session.GetSession();
theUfSession = UFSession.GetUFSession();
isDisposeCalled = false;
//code
//Session theSession = Session.GetSession();
Part workPart = theSession.Parts.Work;
Part displayPart = theSession.Parts.Display;
// Menu: File->Close->Save As and Close...
PartSaveStatus partSaveStatus1;
partSaveStatus1 = workPart.SaveAs("C:\\Users\\Dhaval\\Desktop\\PISTON_9HSE_411_2");
partSaveStatus1.Dispose();
workPart.Close(NXOpen.BasePart.CloseWholeTree.True, NXOpen.BasePart.CloseModified.DontCloseModified, null);
workPart = null;
displayPart = null;
catch (NXOpen.NXException ex)
// ---- Enter your exception handling code here -----
// UI.GetUI().NXMessageBox.Show("Message", NXMessageBox.DialogType.Error, ex.Message);
// Explicit Activation
// This entry point is used to activate the application explicitly
public static int Main(string[] args)
int retValue = 0;
try
theProgram = new Program();
//TODO: Add your application code here
theProgram.Dispose();
return retValue;
// Following method disposes all the class members
public void Dispose()
try
if (isDisposeCalled == false)
isDisposeCalled = true;
using System;
using NXOpen;
using NXOpen.UF;
// class members
// Constructor
public Program()
try
//code
workPart = null;
displayPart = null;
int retValue = 0;
try
return retValue;
try
