Solid edge ST6 - install standard parts
I have problem with installing standard parts to my ST6.
Run (as a admin, i have win 7) standard parts configuration wizard to set locations of parts --> tried all location options, but with no success (see below).
There is some database error with no specify. Also i have tried reinstal SQL server express from Microsoft.
Any ideas where is the problem?
Thank you in advance
RE: Solid edge ST6 - install standard parts
